Originally Posted by
sanfriz
It feels like neutral. It will rock a little around 1800 rpm. It doesn't make any bad sounds. I found another person with similar issues but theirs worked with the electrical unplugged, I just tried that, and it would not move at all. Is there any change my converter pulled away because there was too much of a gap? I honestly didn't, measure, just eye balled it. I read though that if there would be no input shaft speed if the converter wasn't seated correctly.
It does feel like it moves easier, at less RPM, in 2nd and 3rd. Can't reach first.
I ordered GM4L80E Transmissions: How to Rebuild & Modify (The Workbench How-to, 499) so I'm prepared to pull it and go through it again. Just a little disheartening it isn't working after putting so many hours into it.
