Results 1 to 6 of 6
Thread: Stock Calibration Request: 1999-2003 S-10 2.2 Non-Flex
    Aug 2023
    3
    Hello,
    My truck had the motor replaced with a non flex version, the PCM was replaced with a non flex but it was programmed with the flex tune.
    I was able to change the injector scaling and it drives much better but there are a few things that are still not great, warm starts are rich and it take a bit to start and some slight hesitation after cold starts.
    I was hoping to find a non-flex tune and compare the differences, any help would be appreciated.
    1,528
    Have you checked the tune repository?
    Aug 2023
    3
    I do not have access, I am borrowing the interface. Someone on the S-10 forum checked and did not find one.
    1,528
    I think you can create an account without the device if you want to check for yourself.
    Mar 2023
    Eastpointe
    3
    I have a tune, it's close to stock non-flex, a few goodies tossed in if you want it.
    Aug 2023
    3
    Thank you. I will give it a try. The truck is running but I would like to compare a few things to see if there were other differences.
