Hey guys,
We've been running an SD-only E40 on our drift car for years now without issue. When I swap out the LS3 intake manifold & injectors for an LS9 blower setup with 100lb injectors the car runs well long enough for me to be able to tune it, i.e. a few isolated WOT pulls, but after thrashing it for a couple min it will eventually go into REP mode without throwing any codes, a condition which is cleared by simply turning the car off & on again. I suspect there is some sort of limiter/nanny somewhere that is tripped after a certain number of counts, and that the rescaled tune is what's causing it. P0068 has been moved out of the way and ETC TPS Max (#12850) has been maxed out as well. I even tried setting the Reduced Power Mode (#33034) map = to the Normal mode maps, but that made no difference either. I can tell you its not a TB issue because a) same thing happens when we swap it out for a brand new one , and b) no such issues when running the engine NA with an unscaled tune. Should I play with the Engine Diag -> Airflow -> TPS tables? Should I disable 1516 and 2101 altogether in the DTC section even if no codes are being thrown?
I have attached the file & the log, any help would be very much appreciated
E40 drift PCM hydra 2023 ZR1 98RON 28T COG offset TEST.hpt
fault3.hpl
PS - For the rescaled tune I didn't do the usual 50%, because I wanted to maximize resolution. Set the injector size to the max allowed 8 g/s and multiplied the VE table by ~65% of where it should be for everything to fall in line, could this be it?
