Results 1 to 9 of 9
Thread: 2003 TRAILBLAZER LT, 4.2, 4L60E. hard 1-2 shift
    Jul 2021
    3
    what can i change to lessen the hard 1-2 shift on this transmission. this is the only issue i have with transmission. i just got mpvi3 yesterday so this is all new to me. thanks for any info. attached is the current tune, i believe stock
    SoCal
    1,600
    First things first. Before you go messing with a stock tune, does it have a transmission, TAC, or any other codes in the PCM? If so diag those first before messing with the tune. Those do not typically have a harsh shift when everything is bone stock.
    Jul 2021
    3
    0 codes and i forgot to mention po said they put in a corvette servo.
    SoCal
    1,600
    That servo will firm up the shifts.
    Shifts are pretty subjective. Do you have a stock vehicle to compare to? You could soften it up with some adjustments.
    2,915
    I don't like to undo shift firmness from shift kit type parts like that.
    I'd go back to the OEM servo to get the shift you want.
    Tuner at PCMofnc.com
    SoCal
    1,600
    Totally agree. I tell customers no problem on aftermarket clutches, zip kits, etc etc but no mechanical shift kits given the ability to put the shift kit in electronically in a far safer better manner.
    Jul 2021
    3
    Thank you. I’ll try this weekend
    7,890
    The 70E servo might be a better choice. (combined with adding some TM at the 1-2)
    https://www.sonnax.com/tech_resource...for-the-4l60-e
