Results 1 to 10 of 10
Thread: Ac request type
    Jul 2022
    31
    Ac request type
    Does anybody actually know what each type does, not a guess direct facts of what each does and looks for, obviously I know the difference in analog and serial, being the request is via serial data line or a direct 12v signal. But is analog cycling is getting cycling signal via the data line as well as the request and same for analog cycling is getting the high pressure switch via analog? And where does the pressure transducer play into each of those. And then just curious on the passive one. Obviously not fitted is not fitted.
    7,837
    Recirculation Fitted: Fan #2
    Type Fitted: Analog
    Type Fitted: Serial Cycling
    fan2, serial cycling - compressor controls.png fan2, serial cycling - cooling fans.png
    Recirculation Fitted: AC Recirc
    Type Fitted: Analog Cycling
    AC recirc, analog cycling - compressor controls.png AC recirc, analog cycling - HVAC recirc.png
    Jul 2022
    31
    Does it still use and utilize the pressure transducer in analog cycling?
    7,837
    Analog Cycling is simple switches only, no sensors (edit: and, a non-variable displacement compressor). As shown in the diagram. High side cutout, and low side cycling. With pressures equalized (compressor off and system full) both switches are normally closed. Either switch opening disables the compressor.
    Diagrams in order are taken from '99 Camaro, '04 CTS-V, '99 Silverado.
    Jul 2022
    31
    Sorry what I meant to ask was if set to analog and you have both a low switch and a pressure transducer will it recognize the low switch?
    Jul 2022
    31
    Also I believe that analog diagram is either from a super early non v Cadillac/North Star or duramax considering it?s blue/clear
    7,837
    2004 Cadillac CTS 5.7L. The non-V was 3.6L V6 and if it was a Northstar it wasn't a CTS. Looked up straight from GM eSI.
    7,837
    My advice: if you want it to function like stock with the PCM controlling the A/C, then copy one of the factory switch/sensor arrangements and related tune settings. If you want to mix up your own unique batch of parts... don't. Or, build a switch setup that works old-school totally independent of the PCM.
    Jul 2022
    31
    I build/ sell harness probably 100plus harness and just now having an issue with 2 guys that were done recently both pcm I tuned, I set the to analog cycling, one guys fans came on with ac the others didn?t the guy that had come on didn?t have high setting on the fans come on when it should have. iv found I need to switch it to analog, iv got that, I?m just wondering if it still gonna want the signal on 55 or if I need to start running that switch inline on the request.
    7,837
    2000 Camaro LS1:
    2002 Camaro LS1:
    Both are the same "Fan #2/Analog". I didn't realize you were looking for where to put which wire on a specific application, from your first post I figured all you'd need would be an example of what kind of wiring/components are used with each of the tune settings.
