Page 6 of 6 FirstFirst ... 23456
Results 101 to 113 of 113
Thread: Which Wideband is right for YOU?
  1. #101
    Tuner CTX-SLPR's Avatar
    Jan 2008
    Colorado Springs, CO
    115
    Quote Originally Posted by LSxpwrdZ View Post
    I would run a Haltech wideband! I run one of them in my Camaro full time and for the money it can't be beat. It's just as accurate as my NGK is. It also control's 2 sensors and the control box is tiny in size. It does have free air calibration as well. I'm not certain if it's got capability to read NTK sensors or not but mine came with 2 bosch and they are doing fine. I put my NGK in the exhaust with the Haltech and it was reading identical values through my scanner through the EIO of the interface. It's got individual 0-5v outputs for each sensor. They also sale a gauge for it or you can obviously hook it up to your programmable gauge. My only beef with it is the instruction's don't show the afr to voltage transfer function but luckly my buddies work for Haltech America and I got the info from them. 0v=10afr 5v=20afr with 14.70 as stoich. I configured mine to read lambda in my scanner however.
    Thanks for the info. I have the NGK sensor on my JAW that tested good from the guy I bought it from (5Liter Eater) but it uses the same plug I think. I'll have to take a look. With the Turbo6 I don't think I can run a second sensor pre turbo from what I've heard. It'd just cook the sensor.
    Thanks,
    Central TEXAS Sleeper
    USAF Physicist
    Current:
    2003 Lincoln LS (3.0L V6, 5N55S)
    1964 Riviera (465 Wildcat, ST400) 4.1L Buick Turbo6 and SP400 Swap in progress
    1999 Silverado 1500 LS Z-71 Long Bed Regular Cab (5.3L, 4L60E)
    SOLD:
    1970 Riviera
    1965 Riviera GS (465 Super Wildcat, SP400) #'s Matching
    1967 Skylark Deluxe
    1997.5 Regal GS
  2. #102
    Jun 2008
    This information has been a great help... Thanks to all for your responses!
    New to Tuning
    2005 GTO A4
    Current Drivetrain Mods:
    MSD Wires, LT Headers, Hi Flow Cats, 3400 Stall (w/cooler), GTPrix TCM
  3. #103
    Tuner in Training BluBeaSSt's Avatar
    Dec 2011
    31
    I just got my PLX SM-AFR and how do I hook this up to the MPVI?
  4. #104
    Aug 2010
    21
    Quote Originally Posted by 5_Liter_Eater View Post
    Over the weekend I replaced my AEM with the MTX-L. I replaced the AEM because the analog outuput was not reliable as mentioned above. It would shift from day to day and I would have to re-do the offset and/or slope but towards the end I noticed that the output was not even linear (sometimes). I got fed up with it and decided to try the MTX-L mainly because I wanted a gauge type WB to fill the hole im my pillar pod that the AEM left and also because of price point ($189 shipped from Amazon).
    I installed it the same was the AEM was, with the power from the alternator via a relay and ground to body. I have one analog output going to my Aeroforce Interceptor and the other to the AC pressure for piping into HPT. I set up the transfer function in the Aeroforce exactly as it should be based on how I have the MTX configured and it matched up exactly with the display on the MTX across the AFR range from 9.9:1 to 22.4. I didn't have to mess with ground offset at all. I have not hooked up HPT yet so I'll review on that later.
    There are several features I like about the MTX:
    I like that it will read all the way down into the 7's because my target WOT AFR is 11.5 and the AEM would only go down to 10. When I first started spraying meth I was likely richer than 10 in spots but I wouldn't have known it with the AEM since it would not go lower than 10.
    Free air calibration. This was not an option with the AEM.
    I like that the outputs are configurable. By default one reads from ~7.3 to ~22.3 and the other emulated nerst cell but I can configure them both however I like. I will likely set them both to read 8-18 across the 5V range to gain a little resolution. Also, if I wanted to verify that the Aeroforce and HPT are seeing what the MTX says its putting out I can set the outputs to flatline at a certain voltage and see if they match.
    I like that stoich is configurable. Most wide bands are hard coded to show lambda as 14.7 but with the MTX I can set it, so I have set it at 14.2 to account for the ~10% ethanol blend in today's pumps. If I want to run E85 I could change the value again and still tune in terms of AFR instead of lambda.
    The gauge's LEDs and LCD are configurable and independent of the analog outputs. The LEDs sweep from green to yellow to red. I can tell it I want green to represent 10-12 AFR, yellow 12-13 and red 13+.
    I've always steered clear of the Innovate products because I judged they have a reputation for not being reliable but no one has really tried the MTX so I decided to giev it a shot. Only time will tell if it proves reliable.
    Hey 5_Liter_Eater,
    How are you liking that MTX?
  5. #105
    Nov 2005
    Houston, TX
    3,754
    I'm liking it a lot. Very consistent and not one hiccup.
    Bill Winters
    '05 Corvette - Iron Block 408 & TTIX - 928 RWHP / 926 RWTQ @ 21#
    "When life hands you lemons you upgrade to a C6." - Me
    Always post a tune and a log when asking questions.
  6. #106
    Aug 2010
    21
    Awesome, thanks for the update.
  7. #107
    Sep 2011
    36
    I have the Innovate MTX-L wideband and the wide band gauge reads .2-.3 different than the reading in HPtuners charts while scanning. I have moved the ground, calibrated the O2 again and still the same. Any ideas? It is actually off from the stock o2's also. I am using the LC1 calibration when I set it up in HPtuners. Thanks
    2011 GMC Sierra 4X4 SLE Lysholm 2300 Supercharger 5" BDS Lift, 33X12.50X20 Nitto's and 20" Chrome Wheels.
  8. #108
    Aug 2010
    21
    Quote Originally Posted by hhoelle View Post
    You will most likely need to adjust the offset. The LC1 might have a different offset than the MTX. Look for the correct info in the manual for your MTX.
    Take a look here...
    http://www.hptuners.com/forum/showthread.php?t=28176
  9. #109
    Jul 2007
    Shenandoah Valley, Virginia
    3
    Anyone have a recommendation for a non-perminant setup? What I'd like to do (if possible) is remove one of the factory narrow band sensors (while disabling it in the tune) and install the wide band sensor in its place. Next, I'll want to wire the wide band to the pro interface and do my tuning. Once done with tuning simply reverse the procedure.
    Any thoughts?
    Thanks,
    Tony
  10. #110
    Tuner jimbos'ss's Avatar
    Aug 2007
    grafenwoehr germany
    137
    Bill,
    Have you had any issues with the MTX not reading the same as the narrowband o2's or anything that would make you believe it's not accurate? I have an AEM right now and I know it's not accurate. Reads 3% lean across the board.
    Jim
    2001 Z28 M6 .
    Mods:Cam and Headerback exhaust.
    euroLSx
  11. #111
    Nov 2005
    Houston, TX
    3,754
    No. If yours is reading slightly leaner than the narrow bands I would suspect tiny pinhole air leaks at the WB bung.
    Bill Winters
  12. #112
    Aug 2007
    grafenwoehr germany
    137
    I already checked and even put some exhaust sealant stuff on there just in case. No change to AFR, lean 3% across the board. At this point I no longer trust the WB especially seeing how I've gone through two sets of brand new NB o2's just trying to get it figured out, no change there either.
    2001 Z28 M6 .
    euroLSx
  13. #113
    Tuner in Training -MD- HHR's Avatar
    Jun 2008
    Northeast Ohio, In the Lake
    40
    I have had my MTX-L for a while now. It works great. I did have to adjust the voltage offset. It was about 0.3 off.
    The only issue I'm having is using it as a wideband, narrowband, and hooking it to HPTuners.
    The narrowband part starts to read richer and richer, until I recalibrate, but I'm not sure if it is the cars PCM or the wideband. No other J-body people with the same PCM has run it as a narrowband and a wideband. I love it as a narrowband since my stock O2 sensor is not heated, and the car doesn't run 100% till it is warmed up, but it has done this since I put a header on years ago.
