I have a 2006 GTO i am working on and it has a real lumpy cam in it and when coming to a stop at stop signs or redlights the idle would dip well below 500 rpms and sometimes would stall.
here's what i did to correct the problem and so far it appears to be the cure:
under---- Idle>Idle RPM>Adaptive Idle Proportional>Airflow: add 4 to every row and column(transition and coastdown)that's on the positive side (32 rpms - 512)
under---- Idle>Idle RPM>Integral>Airflow: multiply every row and column(transistion and coastdown) by 2 that's on the positive side (32 rpms - 512)
do not mess with any numbers on the negative side as this seem to negate the changes on the positive side.
ben
