Custom output ratio to make 9:16 for Instagram video
Is it possible to change the output ratio ? I've looked in advanced but can't see it.
At the moment I have to render in RR then load into a different editing software to crop it to the desired 9:16 ratio ?
Or is it not possible?
It doesn't look like RaceRender currently supports portrait resolutions. You could go with something like 4:3 or 3:2 to limit the amount that you actually need to crop, but you would still need to use some other video editing software to do that cropping.
That's what I thought, but thanks for clarifying I hadn't missed something obvious.
yes it's a pity we can't in a configuration file to add new ratios like 9:16
