I've had my MPVI2 for a few years now. I've played with it some, but this is my first real attempt to tune/calibrate a vehicle. I think that I've done okay, but i'd like some feedback. I have several questions as well lol. I have attached a google drive link with every single step from the entire process for your viewing pleasure.
https://drive.google.com/drive/folde...usp=drive_link
The vehicle is a 2006 GMC Sierra 1500 5.3L LM7 (non-flex) 4WD. It is stock, besides cats removed, a flowmaster 40 (I think) exhaust, and oversized A/T tires. I am using an AEM UEGO 30-300 wideband sensor. The truck also has a fresh set of GM Genuine Knock Sensors, ACDelco plugs, and a set of AutoZone coil/plug wires. It is currently driving phenomenally, I'm honestly surprised how much of a difference just tuning has had on it.
The order in which I tuned was Transmission, MAF, VE, and then spark. I only tuned the low octane table on E10 87 octane from Murphy's, any spark that I added to the low octane table was also added to the high octane table because that made sense to me I guess. I will revisit high octane with actual 93 octane fuel in the future.
My first question is, How much EQ error is generally considered "acceptable" for MAF and VE? I felt like I was chasing a ghost trying to dial in the last 2-4%.
Also, After my last spark file I was still showing up to almost 2 degrees of KR at one point. This was after I added the high octane table and knock learning back in. Is this something to worry about, or should I just let the knock learning take care of it as it picks up knock and blends the two tables?
Where do you guys typically set PE to come in at? and how fast would you normally ramp it in?
Thanks in advance!
