Results 1 to 5 of 5
Thread: Tire Pressure
    Dec 2006
    Fort Lauderdale
    171
    Tire Pressure
    Wondering if anyone knows of a way to turn the tire pressure sensor error msg off. This is a 06 C6.
    Apr 2003
    Almost 2000 feet.
    7,876
    GM Dealer
    Always Support Our Troops!
    Dec 2006
    St. Petersburg
    49
    I wish...... that F*&^%$# "SERVICE TIRE SENSOR" is the most annoying part of my life at this point, I just don't have the time to get to the dealer
    my friend get a good strong magnet first then follow these steps
    Select the ACC position on the ignition switch. Simultaneously press the keyless entry transmitter lock and unlock buttons until a horn chirp sounds, indicating the TPM learn mode has been enabled. Starting with the left front tire, hold strong magnet against the tire sidewall close to the wheel rim at the valve stem location and wait for a horn chirp. After the horn chirp sounds, proceed as in step 3 for the next 3 sensors in the following order:
    Right front
    Right rear
    Left rear
    After the left rear sensor is learned, a double horn chirp will sound indicating all sensor IDs have been learned. Select the OFF position on the ignition switch to exit the TPM learn mode
    Feb 2007
    5
    great post - do you think this works for other's too
