Results 1 to 6 of 6
Thread: newbie in tuning 5.3 camed headers, rest stock
    Jul 2022
    3
    hi guys
    anyone can help and check my tunes ?
    2400 to 3000 the car have lot of retard... payed lot of money for tune and it it not what I want..
    here are the files
    Petr
    I def. do see some knock in your tune, Looks like small changes to ve table and Maf table. No changes to Low Spark table,
    i see alot of idle adjustments and alot of high spark changes but thats about it on engine side.
    Jul 2022
    3
    Quote Originally Posted by tana99ss View Post
    yes I did, but the knoc killing me orround 2000 RPM.... what to do
    13,576
    Kinda looks like you payed money for nothing.
    The VE is basically all stock, they just add fuel everywhere by like 10%. So they didn't even tune that correctly.
    Some timing should be removed from the tune. The high octane table is raised but they left the spark adder table there, so it can add even more timing.
    Power enrichment is still basically stock, it's has long delays that make it take up to 90% throttle to enable.
    You still have stock injectors on a cammed 5.3, good bet it's going to need more injector. Also make sure you are running around 58psi of fuel pressure all the time even under load. And make sure nothing is rubbing on anything that could cause the knock sensors to pick it up.
    I can't view the log to see anything else right now.
    Jul 2022
    3
    Thank you very much
    Im trying to have everything neat.. have stock injectors an comp cam double spring, standard rockers.
    will try tmrw and let you know
    Petr
    Potential Tuner kelvinberroa's Avatar
    Mar 2019
    Davie,FL
    7
    a lot of KR. looks like you just gave away your $$ for nothing.
    @bms_tuned
    GM EFI Tuning
