My 03 5.3 silverado won't idle when hot with my new stage 2 sloppy cam
That is not the hardest cam to tune for idle. I ended up having to work on the idle proportional airflow tables to finally get mine to settle down.. You have NOT included a current copy of your TUNE and/or a LOG so..... essentially NO ONE can comment on how to help you move forward. Do you have HP Tuners? Can you post up a log and your tune? Have you already corrected your VE Table and MAF table? What other mods do you have? Stock injectors? What type of fuel system do you have-if it is not stock?
start here
come back when youre done and post up the tune
https://forum.hptuners.com/showthrea...e-(w-pictures)
where is the button in the softwear you can push to just make it run good
