Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Truck Norris Cam Help
    Apr 2019
    14
    Hey!
    I am new to tuning and am looking for some help tuning my 01 T/A 6 speed. Details on the car are as follows
    BTR Truck Norris Cam
    Beehive springs
    BTR pushrods
    243 heads
    1 7/8 Long tubes
    SLP Catback
    Is there somewhere to get a base tune to start working off of? I figure I cant be the first one to do this setup
    Jan 2015
    Arizona
    447
    Quote Originally Posted by tntransam View Post
    Hey!
    theres like 6 TN cams out now. Which do you have?
    And, start here, and come back when youre done. ----> https://forum.hptuners.com/showthrea...dCDR6D7t30xBWA
    7,648
    If you'd prefer a normal link without the Facebook click-tracking data on the end:
    https://forum.hptuners.com/showthrea...e-(w-pictures)
    Apr 2019
    14
    Quote Originally Posted by bk2life View Post
    I will check the part number when I get home. I ordered it as a kit from Michigan Motorsports
    Mar 2022
    Indiana
    2,945
    Don't forget fuel injector part number.
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    Hey!
    Beehive springs
    BTR pushrods
    243 heads
    1 7/8 Long tubes
    SLP Catback
    I would advise you to work with your normal basemap
    if you don't know where to start you can ask for help in the forum we will all help you
    Jan 2015
    Arizona
    447
    thanks amigo... ive had that link for along itme saved on my computer, never noticed how long it was
    Apr 2019
    14
    Stock injectors
    Apr 2019
    14
    Quote Originally Posted by Josue Galban View Post
    10-4. I will download the factory map and read through that tutorial that was posted and go from there. Thanks
    13,565
    Stock injectors
    Get bigger ones.
    The stockers won't be big enough.
    Jan 2023
    Venezuela
    205
    what do you have, gm 3rd gen, I mean the ECM, you can look for a base map in the repository or if you don't get it I can send you one, I have several that could work for you to start
    Nov 2006
    2,742
    Get bigger ones.
    Respectfully disagree.. Maybe your thinking of 99-00 F-body?
    I've made 490 at the tire with the 01-02 F body injectors.. This setup will not come close to that.
    Tuner at PCMofnc.com
    Mar 2022
    Indiana
    2,945
    Respectfully, I'd have to see that. Serious doubts about pulling those numbers NA on a 5.7. Or did you mean those injectors used with boost or a stroker?
    And if it's true then you'll be seeing a few orders coming your way lol.
    Nov 2006
    2,742
    Oh we've made 500 rwhp at the tire. My own 01 Z06 did it. This is not that hard of a setup. A decent sized cam and trick flow heads with all the other little bolt-ons will do it. Most end up in the 480's but a good handful of them at 490-500.
    Before anyone says anything.. a LS6 and LS1 bottom end are practically the same. The difference is in the top end.. heads/cam.
    Mar 2022
    Indiana
    2,945
    I know. For the block it's just the bay-bay breathing in the crankcase.
    PM'd
    Apr 2019
    14
    So the one I have is
    Intake Duration 212
    Exhaust Duration 22X
    Intake lift 0.553
    Exhaust lift 0.553
    LSA 107.5
    Hope this helps
    Dec 2019
    MS
    567
    Is this with the 28# injectors?
    Nov 2006
    2,742
    Yes
    Dec 2019
    MS
    567
    Yes
    What was injector duty cycle?
    Nov 2006
    2,742
    It wasn't 100% but it was up there.
    33# LS2 injectors I've made 520 NA..
    42# LS7's i've made 620 pretty comfortably.
