Results 1 to 2 of 2
Thread: Engine Fule rate Liters Per Hour L/H into MG ?
    Hi everyone i have been trying to figure out witch fuel maps my SID209 ECU is using...so what i am doing is logging in VCM scanner at idle and then going thru VCM ediotor and searching thru my fuel maps and trying to match the Engine fuel rate Channel L/H to a area in the fuel map where idle will be.....But its not adding up from Liters per hour(L/H) .
    i have added pictures to show this.
    .....i have a channel Engine fuel rate in L/H on idle its 0.45 L/H witch converts to 450,000mg.....How ever if you look at my Fuel map table in the Highlighted area i can only see 2.500 to 6.790Mg ? i am off by 449,995mg ? why is there such a big difference ?
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    476
    Either in the scanner or in the editor you should be able to change the units. In the editor up top you will see the green mg. Click that and it will start to change the units. If it has liters/he it will show up
