As the title says can hp tuners program a new TCM for work with the car? The tcms say they need to be programed to work I have the file off of the old tcm so can I just "write entire" and be good to go?
2001 V6 M5 firebird: drop in K&N, 12bolt with posi and 4.30s, magnaflow muffler, gutted cat.
9.5 at 73 in the 1/8th on street tires
No. Needs to be SPS/TechlineConnect programmed then you can modify the programming with HPTuners.
New modules that I have purchased had zero programming in them and when I tried a year or so ago when my SPS was down for a day it wouldn't. Given that was an older version of HPtuners and I have not tried with any of the newer version.
He said "New" so I figured it wasn't a used or rebuild.
I only tried the one time as from that point on I just use my SPS/TechlineConnect.
Who buys a new T42 when you can get good used ones for $10-15?
I've had MANY customers who are fixated on dealership only parts. Modules I get from there are a mix of rebuilds with software and VIN's programmed on them to full on totally blank brand new modules.
OK, let me rephrase: Who, working on their own car and without access to the dealership tools, buys a new $150 T42 when you can get good used ones for $10-15?
See my above posted success with a T43 Write Entire
Good luck
Roy
T43 is not a T42, and a module that's been programmed with *anything* before is not the same as a new one that's never been initialized.
I've successfully been able to write entire T42 and T43. I won't guarantee you won't have problems but I've done it more than a few times with no issues.
Tuner at PCMofnc.com
