I'm working on a swap into a c3 vette my pcm is 2010 camaro ss with a t42 tcm and a 06-08 4l65 15 pin harness. It's throwing a code for pressure control solenoid A as well as TCC pressure control and clutch control. light throttle the car shifts 1-4 fine. when i get on it about 60% tps it doesn't shift. The pcm commands the shifts and it feels like it does shift it just slips bad. The trans is a fresh rebuild with only about 5 miles on it. Even pulled the pan and replaced the solenoids it was throwing codes for as well as the internal harness because it was leaking. I have traced each wire from the pcm plug back to the tcm and all are good and where they should be. I've attached the last log and the file I'm working with. About half way through the log is where I got on it to do a light pull and you can see the gear change commanded and rpm keeps going up until I lift and it shifts.
