LGZ swap No start
Hi All,
I am currently putting a 2017 LGZ and 8speed out of a Colorado into my 14 Genesis coupe and it is a no start. At this point I have all of the fuses getting power to the computer , all of the run/crank and acc/run circuits are fine, everything has power where it needs to be and ground where it needs to be. The problem seems to be that there is no injector activity. The coils have juice, the car also sends the rpm signal. I have disabled the vats and the starter diag sequence so the starter is wired directly to the ignition of the Genesis coupe and when I go to the start position on the key, it turns on the fuel pump and the starter turns the engine over. So I have spark, I have fuel pressure up around 2700 - 3000 psi at the hp fuel rail, I have all of the sensor signals working but I am not getting gas being injected. All of the wiring is fine, all the injectors are hooked up and getting 64 volts and 12 volts when you read the data on my Launch scanner. I am just not getting spark.
Anyone have any input, I would greatly appreciate it!
Jon
