Results 1 to 7 of 7
Thread: lock up won't engage after engine gets hot on C5
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    Hey guys. So we have a 2000 C5 with built ls1 and 4l60. The trans has a single disc circle d 3600 stall tq converter with a trans go 2 shift kit in it and a tru cool 40 cooler. We have the trans only lock up in 4th because it doesn't like it in 3rd. But here's the deal, when we get on the highway everything shifts as normal and lock up engages like it should. But then the engine gets warmer, like 200* and then the tranny gets warmer and will climb to the 220"s*. Then for some reason the torque converter will go unlocked and the tranny temp climbs even higher in the 240"s* and it won't go back into lock up until the car cools down. Also one other thing is we switched the rear gear from a 273 to a 3.42. I'd appreciate if someone could take a look at the tune and see if something sticks out or do we just need to get a better radiator because we are still running the stock one? Thank you.Corvette Tune.hpt
    L99 A6 - DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, IR EGM-205 Oil Pan Baffle, CAI Intake, Fast LSXR Intake Manifold, Nick Williams 103 TB, ZL1 Pump, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter
    Mar 2022
    Indiana
    2,944
    Hello again, Joe.
    C5's have the speed sensor in the diff. To change gear ratio you must change the tire size in the tune. Put the gear ratio back to 2.73. Use the gear/tire wizard and multiply tire size by 0.7982. 2.73/3.42 = 0.7982. Should come up with 21.31 tire size in your tune.
    TCC apply/release spreads are too high. Stock differs by only 2mph. Your tune has a difference as high as 20mph.
    Why is TCC Duty Cycle Minimum set so low? Try 90% not 10%.
    Sep 2021
    Austin
    292
    One thing though is I can't see what the tire size is in the tune. In the gear / tire wizard it ask you what your tire size is which I believe is 26.70. Should I just put the current tire size the same as the new?
    Mar 2022
    Indiana
    2,944
    If it's stock tire size use 26.70*0.7982. For aftermarket take your diameter measurement and multiply by 0.7982. Keep gear ratio 2.73.
    Stock example: 26.70/2.73 current -> 21.31/2.73 new. Press adjust. Save. Write the tune.
    Mar 2022
    Indiana
    2,944
    Btw it might have not liked 3rd because TCC duty cycle was too low.
    Sep 2021
    Austin
    292
    Ok I appreciate your help I'll test it all out in a couple days and let you know how it went?
    Mar 2022
    Indiana
    2,944
    You're welcome.
