Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: general setup questions but not anything i see reference to
  1. #21
    May 2023
    16
    but it does say @43.5 psi/3 Bar not sure about the equation to convert it to 50psi (idle) / 56=58 wot (no vacuum to reg)
  2. #22
    May 2023
    16
    also didnt catch it at first but that 20.5 lb./hr. was @ 43.5psi./3 Bar not sure about equation to convert to my regulator 50 psi idle/ 56-58 psi wot (vacuum unplugged) i would imagine it would be worth checking.
  3. #23
    May 2023
    16
    sorry didn't look like I posted the last one
  4. #24
    405
    2,326
    00 60 injectors are 24.8 same as 99.
  5. #25
    7,643
    The 'best source for that info' would be a tune file from something that had those injectors installed from the factory. Because injector data is way more than just the flow rate.
    Confirmed by the VIN that the truck this file came from used that injector part number (and same regulator type, you still need to confirm with a gauge that your rail pressure is ~58 at key on/engine off):
    2000 Sierra 2500 1GTGC24U1YE377854 6.0 4L80E 1299080621.hpt
    Open your file. Open the 2000 Sierra file as 'Compare'. Copy these tables from the Sierra into your file:
