Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Another Newbie No Start
  1. #21
    Mar 2022
    Indiana
    2,939
    Alright good luck. Thanks for keeping people updated. When others view the post it's nice for their sake to have confirmation.
  2. #22
    Nov 2017
    1,464
    What are you bumping? You need to give an update on what’s going on since your last post indicated you have a map problem,
  3. #23
    update!!!
    car fires right up now i have real 2bar map installed. next issue is that the car dies immediately after put into gear. also ecm will sometimes cut fuel and spark after idling for like 2 minutes . i clear DTCs and itll fire right up and idle no prob. wideband is being whacky atm so apologies for the lack of data there. attached current tune and my attempt to put car in gear
  4. #24
    Here are the list of DTC?s set when it dies randomly sometimes. Sorry I can?t attach photos from my phone I guess
    P0102 - Mass or Volume Air How A Circuit Low (Pending. Current. History)
    0x10: P0103 - Mass or Volume Air Flow A Circuit High (Pending. Current, History)
    0x10: P0106 - Manifold Absolute Pressure/BARO Sensor Range/Performance (Pending. Current)
    Ox 10: P0443 - Evaporative Emission System Purge Control Valve Circuit (Pending. Current)
    0x10: P0449 - Evaporative Emission System Vent Control Circuit Intermittent (Pending. Current)
    0x10: P0452 - Evaporative Emission System Pressure Sensor/Switch Low (Pending, Current)
    Ox 10: P0463 - Fuel Level Sensor A Circuit High (Pending, Current, History)
    Ox 10: P0522 - Engine Oil Pressure Sensor/Switch Circuit Low (Pending. Current, History)
    Ox 10: P0650 - Malfunction Indicator Light Control Circuit (Pending, Current)
    Ox 10: P0654 - Engine RPM Output Circuit (Pending. Current, History)
    Ox10: P0740 - Torque Converter Clutch Solenoid Circuit / Open (Pending. Current)
    Ox 10: P0785 - Shift/Timing Solenoid (Pending, Current)
    Ox 10: P1514 - Airflow to TP Sensor Correlation High (SES, Pending. Curent, History)
