99' Vette with a mostly stock LS1 other than a stage 2 cam upgrade, normally aspirated. I've tuned the VE table but the AFR is still too lean when under power enrichment (WOT). While I can command the AFR lower using the PE multiplier table, the observed AFR is still well above the commanded AFR. The cells in the VE table in play under these conditions are already maxed out at 100. My question is why is the observed AFR still too lean? Looking at a single point in the log, here's what I see:
Observations
commanded AFR: 10.6
observed AFR: 13.6
RPM: 4900
Manifold pressure: 95 kPa
Configuration
My stoich is set at 14.63
PE multiplier at 4900 rpm is 1.375
VE cell at 4800 rpm and 95 kPa is 100
So the math looks good on the commanded AFR. But it appears the ECM still isn't delivering enough fuel. I have verified my fuel pressure while under WOT, it's good at 58 psi. The vehicle has 84K miles on it with original injectors. Could this be an injector problem?
My wideband reads well at idle and cruise speeds, always near 14.7 when the engine is warm. Could the wideband behave different under WOT? I have the wideband mounted about 18" in front of the cats, so it's not at the factory O2 bung on the exhaust manifold.
I do get some heat soak from my IAT sensor. But when I do the math on that, that would only contribute about 5% to the lean condition. My wideband is showing much more than that (from commanded). Given air mass is calculated as follows, I don't see anything else that would cause the airmass to be miscalculated. My MAP readings seem fine in the logs.
Air Mass = (Engine Displacement * RPM * VE * (Barometric Pressure / MAP) * Sqrt(IAT / 273)) / 2
So it leads me back to injectors. Could 84K mile injectors just be partially clogged and not flowing fuel per spec? Is there some other table in the tune that needs adjustment?
