Results 1 to 5 of 5
Thread: Ford 2012 ECU "PATS" problem
    Jul 2008
    Hey guys
    I have a 2012 Ford 3.7 with ECU from a mustang that I am attempting to use in my open wheel mountain race car. We have wired the motor and various sensors to the ECU. We "I" thought when I pulled the tune from the Mustang prior to pulling out of the car that I could simply disable the PATS. I am pretty sure I was wrong. We have wired starter and ignition to toggle and push button and fuel pump to a switch. Of course we cut the crap out of the harness and do not have any body control module availability. I can scan and write entire tunes back and forth from the PCM but it will not start. We have confirmed that it is not getting any SPARK. I assume that something in the more than the TUNE needs to be done to bypass the PATS immobilizer stuff. ALSO to note I have not got to wiring in the electronic foot pedal. I was told by a Ford tech that it would still start and idle? I do question that, however when we try and crank the car and I am watching live scan data it does show a throttle position at 9% and spark at 14% with 190 RPM.
    Does or has anyone done this.. I didn't think it would be that problematic.
    Oct 2016
    Poland
    1,744
    PATS needs to be disablem in eeprom
    Jul 2008
    Thanks for the reply Would clearing KAM do the trick I did see a option in the VCM scanner special function to clear the KAM?
    Oct 2016
    Poland
    1,744
    No, you need other tools to access eeprom. HPT wont do that.
    What ECM is it?
    I have done a few of them for coyote swap guys but I don't know if that would be the same method on that ECM. I would have to check and see.
