Originally Posted by
Chase2604
Sorry for not getting up to op temp in those logs. Completely forgot. So far I have tried lowering timing in the idle portion, re-tuning ve and maf, re ran the russ k raf config. Adjusted follower settings, and I'm sure there's more just as trial and error. This all started after installing the loose converter I don't understand why that would change it, other than adding more load on the engine causing it to no overshoot the idle? I'm just at a loss at this point. I will get you logs that get up to operating temp later today. Thanks for all the help.
Edit: I do have ac, but haven't really messed with it especially with this issue. I installed the 1500hs fans in it. Built a wire harness to have 2 speeds and pin into the ECU. Tried to copy the fan portion off a vehicle that came with fans factory. I am still learning and have nobody to go to for questions, so everything I have done is either what I have read on here, or trial and error..
