Results 1 to 8 of 8
Thread: Looking for some help, I'm running lean
    Jun 2021
    Las Vegas Nevada
    7
    I'm having an issue where my car runs fine for a little while, then for some reason starts to lean out.
    so I'm trying to get some ideas on where to look first.
    2012 Camaro, stock 6.2 block and rotating assembly, ported heads, BTR stage 3cam, tvs 2300 running 12 psi boost, ID 1050's Fore dual pump setup. (more info if needed).
    it looks like it runs good for a little while, then for some reason, the ST Trim and LT Trim starts to inch up, until it starts to get so high that it flags the Check Engine light.
    so the issue is some part of the fuel delivery system is failing, and I'm looking to figure out where to start.
    MAF Sensor? Injectors getting clogged? O2 sensor misreading? I have a Wideband sensor kit that I haven't put on, but finally got ready to get started.
    interesting log file, if you want to review. the short one is just a drive around town, you can see about 10 minutes in the trim on bank one just starts inching up.
    the second log (if i can upload two) is just a fun one of me at the race track, but you can see the LT Trim on that one going way high
    any input you have will help. I'll might have to go to my shop to have it looked at, but I just hate going in with no information. I like to know as much as i can before i ask someone else to fix something.
    Bryan
    Second attachment didn't make it
    Jun 2021
    Las Vegas Nevada
    7
    Added tune file
    Added the tune file for review
    Jun 2021
    Las Vegas Nevada
    7
    FYI, I'm replacing the Upstream O2 sensors now to see if that helps. the car has 98k miles on it, so things tend to start going bad. it was the cheapest and easiest fix, and even if its not the issue, it nice to have the new sensors in.
    Jun 2014
    Boulder, CO
    204
    Your Injector Offset vs Injector Temp table is zeroed out, which is probably wrong. You should have data for your particular injectors added to that table.
    Tuning Addict
    Jan 2015
    6,821
    There's no doubt that your injector tip temp needs to be dialed in especially since you're running a blower and trims are changing - you'll need to log a lot more to dial it in, but this really looks like an issue with bank 1. Vacuum leak at the injectors through an Oring, loose header seal, injector issue, bad O2 or something like that.
    ~Greg Huggins~
    Jun 2015
    TN
    189
    You have a "CL-Fault" on your fuel system status channel. 90% of the time that is caused from a bad O2 sensor. Changing them may fix the fault.
    RPS Twin Carbon Clutch
    Kook's Headers
    Ported Supercharger
    Cold Air Inductions cai
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
    Nov 2006
    2,751
    This is a bit lean.. yes. but the bigger problem is the split between left and right side.
    Check for exhaust leaks, vacuum leaks, and if that looks ok I'd try a fresh set of O2 sensors for the front.
    It doesn't appear like the car is missing but that could cause this too.
    NO harm in leaving in injector tip temp zeroed out. Quite a few GM cars from the factory have this table zeroed out. It causes issues on reflashes.
    Injector tip temp would not cause the almost 20% split between driver and passenger side fuel trims.
    Tuner at PCMofnc.com
    Tuning Addict
    Jan 2015
    6,821
    I wouldn't recommend leaving it zeroed out - dial it in... Problem is you're running a PD blower - lots of heat especially with boost turned up. What happens with this is more heat from the blower plus more heat building in the combustion chambers plus running leaner plus maybe a back to back pass and now where you were running in the 11's on afr you're now running in the low 12's or leaner in some circumstances. Seen it too many times and you know what happens with boost, heat and being lean...... I've only ever seen one tune where it needed to be zeroed. You can dial it in with "rich after flash". There are write ups I've done and some others for this. Once right it doesn't matter how many back to back passes are made or how hard it's run - it'll stay at the afr's being commanded. You can even set it up to go a little richer if you like... You'll be surprised with how consistent the car runs afterwords too. I've had them running back to back with no breaks half mile passes that could have been bracket raced
    As I previously stated - this most likely isn't your problem - you most likely have an issue on bank 1... Doesn't mean you don't need to dial the tip temp in too though
    ~Greg Huggins~
