Kinda giving up here... Can t seem to get rid of the KR , tried less timing adding PE @1.19 and correcting AFR Err Maf...
It runs goos ides good etc but KR ..OMG
Might just pull MSD and go back to OE for my track day next week ..
If this is what you are referring to, then i am fighting the same thing. what are you cam specs? long tubes? bigger throttle body? I'm currently working on a speed density closed loop tune and it has helped alot. I have been working with GHuggins and things have significantly improved from what it was. Just from glancing at your log, your fueling is still not hitting the target AFR. Looks like you are around 5% leaner than target AFR. I would add ETC TORQUE MANAGEMENT TYPE, FUEL CUT TORQUE MANAGEMENT TYPE, AND SPARK TORQUE MANAGEMENT TYPE in your channels. That can help identify why you are getting spark cut sometimes.
TSP 2.2 cam , Vararam CAI , and the Mamo MSD ..stock TB .
No issues at all with previous tune, I?ve been running for three years, put the MSD on all kinds of issues.
Just increased PE ratio to 1,20 raised maf frequency by 5% still KR ..
Anyone wanna buy a MSD Manmo intake ?
How much lol?
Have you re-tuned the airflow side for the intake? It's going to be making different cylinder pressures in different areas than your other intake. Your spark has to account for that, but first you have to know where to make changes.
hmm.. odd that the intake is the only change you made and are getting these issues. Im TSP stage 2 with msd intake ported by myself. Are you at least hitting or very near the AFR target now? It's frustrating that a hyped product has sooooo many issues starting with quality. I sent my 1st intake back believing it was defective. once i received the 2nd one i began to read the reviews that started popping up. Overpriced low quality product for sure. id also add cylinders 1-8 knock retard in the channels just to monitor if its certain cylinders or all of them
I?ve been taking LTFT copy pasting into the VE Half percentage..
Prob ,
$1250 fpr MSD with FIC 850cc injectors. Brand, new clamshell gasket, and O-ring seals..
Have to make a decision in a day or two.
I even had ?Pat G ? do a tune for me supposed to be one of the best in the country his tune also had KR issus ..
I normally use the LTFT + STFT and paste into VVE half percentage. I have my cell hits at 50 so it takes some driving to get good data.
Will try that
Injection timing can cause Knock Retard as much as anything. With those injectors and the better flowing manifold you might want to try advancing it some and seeing how it responds. If you have too much raw un-atomized fuel it can cost you up to 4 or 6 degrees of timing and honestly I'm not sure I would worry over 1 degree along.
~Greg Huggins~
Pulled few Degs of timing from 4k rpm / @55 G and up ,,, Added good 15% more Maf freq .
Finally NO KR !!! did pull up to 5700 rpm . Still lean up top have to work on High Maf .
and to dial in fuel trims tomorrow.
good deal. Have you tried to dial in your VVE table? It appears to be stockish
Take a look at time index 11:49:20-23. AFR commanded is showing rapid in and out of PE. This is reflected by the wideband. The throttle is being closed for some reason here. Look what it does to delivered engine torque as well. Also seeing misfires.
You didn't fully implement PE settings from my example for one.
The throttle fluctuation I can't explain, unless it's a torque limiter.
Yeah Traction Control System ETC torque management set to 479 ft-lb max. Throttle does start to close at this point, according to the log. Drop out of PE ensues because of thresholds.
It's best to have PE based on MAP not throttle position so much. Look at my example. Look at any Corvette stock file.
Also, there's still KR. Looks like it happens roughly every time MAP is above 60kPa and spark is above 30 degrees. Try deflating that goofy bulge in the mid airmass/mid rpm range of the spark table.
About like the attached.
For manifold volume you have 16,387cc. With the MSD intake I'm getting that your volume should be 14,240cc.
Manifold Volume = Intake Volume + Port Volume = 12,080cc+(8*270cc)
The actual is going to be a little higher since it's ported, but I highly doubt Mr Mamo ported 2 liters of plastic out of your intake lol. Don't forget to add the tiny bit of volume if using a throttle adapter for the stock LS7 throttle body. That's pretty easy to measure (should be around 10-20cc depending on thickness of plate).
Engine>Airflow>Speed Density
This will help some with the AFR transients in your log.
So I pulled MSD went back to OE intake and old tune been running for years NO ISSUES AT ALL NO KR then did log after re-installing OE intake and Im getting KR !!!! WTF !!!
Here is log from old tune no KR then new Log from tonight have KR . Old tune posted say what you will but car ran great never issues 5-6 track days a year for past 4 years .. Something has is different or changed ? Getting KR at low rpm ? and some strange spikes in AFR Err super lean in some cells for brief second >>> maybe my Maf is going bad I am stumped same tune same intake etc know have KR?
Maybe MAF. Knock happens right on the edge. How do your spark plugs look? Heat range and gap? Bad batch of gas?
