Anyone have the stock file for 8L90 Yukon Denali w/ 6.2? I saved mine but i had to restore the backup from my Diablo tuner first. Just concerned the file is saved wasn't the stock one but don't know how to tell via the parameters.
You should be able to find one in the repository - hptuners.com - if you don't have an account you'll need to set one up, but it should be an option after you click on your name.
Otherwise GM made OS updates and to be 100% everyone will need your year model and OS number to match. I've got the truck and Caddy versions but not any of the Yukon specific. The caddy should be the same, but they changed with different driveline options.
~Greg Huggins~
I'll check there. Thank you!
