Originally Posted by
SiriusC1024
Ok glad you found the culprit. I've been going over the tune wondering wtf happened.
I was wondering about the O2 being bad. Didn't see any codes, even pending, but it still might not have had enough time to register. Get a new pair of Denso's in the front. They seem more resilient to the extra fuel in the exhaust stream due to overlap of cammed cars.
The wideband will not interface with the PCM. It runs as a standalone, but you can get telemetry from it to show up in your logs. They're a great tool. AEM is a good unit. I get telemetry off the serial port and adapt it to USB.
That fuel pressure has to be 58psi by the way. I see you have some ideas about how to go about fixing it.
Check to make sure that the return line from your regulator is dumping straight into the tank without obstruction. I'm not sure about your 3rd gen Fbody tank, but some cars have a fuel pressure regulator in the tank on the return line.
May consider a digital fuel pressure gauge and transducer in addition to a wideband.
That carbon buildup will clear up some once you dial in VE to get fueling correct. One trick is to run marine grade TC-W3 2-stroke oil in the gas at a ratio of 1 ounce per 5 gallons (640:1). Sounds ridiculous at first, but it keeps the carbon cleaned off as well as lubricating the upper cylinder and valve stems/seats. I always run it in mine. If you do it make sure TC-W3 rating. One thing to keep in mind is that heavy carbon like that might be a sign of poor fuel atomization, which will happen if your fuel pressure is low.
