Results 1 to 3 of 3
Thread: 2018 Mustang Gt Locked IMRC Adjustments
    Dec 2022
    17
    Hello everyone recently the IMRC shaft broke in my 2018 mustang gt, rather than getting another intake manifold with IMRC's it was recommended to me that I just get one with them locked out. After looking through the forums trying to learn the proper adjustments to make I didn't find much so I decided to take what I learned and make some adjustments...
    The first thing I did was go to the IMRC tab and and disable all of the IMRC components and set them to open. Once I did that I went in the variable cam section and disabled map points 0-13 and snap to point 0-13. I adjusted the the mapped points and distance tables regarding emissions reduction and optimum stability to use map point 14 which is 0 IVO , 0 EVC. Car started and drove fine, it had a little hiccup doing a quick rev but I came across this one parameter that confused me a little and I just wanted some clarification.
    With the IMRC configuration parameter having all the mapped points set to open do I need to still disable mapped points 0-13? Also if I am missing any other changes please let me know I appreciate all the knowledge.
    Dec 2022
    17
    Side note I have not tried it on the car with the IMRC configuration all set 1 when I initially tested the car only 14-26 were set to 1. Testing the theory this weekend.
    Mar 2022
    Indiana
    2,945
    Pretty sure position sensor stays enabled.
    Setting IMCR config 0-13 to 1 wouldn't be correct. Look at the spark tables.
