Results 1 to 13 of 13
Thread: Logging question
    Logging question
    I am trying to log Spark Retard, Spark Advance, and Spark Knock. You can see in the picture that I am only see data in the one row. I also am showing the settings from one of them. Can someone help tell me what I seem to be missing that I am not getting it to fill in more. On the data log I did run through loads and rpm. I did have it to 100% at one point when I look at the load channel in the log. But the table is not filing in. It is a 2014 GT500
    Jan 2013
    Hawaii
    2,101
    Quote Originally Posted by mlecy View Post
    Change engine load from percentage to number.
    I made the chance but it didn't seem to make a difference.
    Jan 2013
    Hawaii
    2,101
    When you select the parameter, click the gear icon on the top of that window. This eliminates all the parameters not in you data log. You can then select the load you logged and say no to the generic parameter prompt.
    That seems to have done it. The table is filling in now. Thanks.
    Mar 2018
    447
    "When you select the parameter, click the gear icon on the top of that window."
    Could you show a screen shot of this?
    Jan 2013
    Hawaii
    2,101
    Quote Originally Posted by K44 View Post
    Example of searching for period using "per" with gear unchecked.
    Example of searching for period using "per" with gear checked.
    Mar 2018
    447
    I have a blank box where you show a gear icon. Does this only work when connected to the car or do I need to contact support?
    I was not connected but did have the profile loaded for the car.
    Jan 2013
    Hawaii
    2,101
    You have right clicked and are tring to add a new parameter to your channels list. Those arrows are "show polling or broadcast channels". Broadcast is mainly the inputs on the MPVI pro devices. Polling is the OBDii data.
    This gear shows when adding a parameter into the chart v time, graph, or gauge areas.
    Mar 2018
    447
    Quote Originally Posted by murfie View Post
    OK I see now. It would be helpful if this was on the channel list also.
    Jan 2013
    Hawaii
    2,101
    Not sure I follow what you mean. The channels available to be added to the channel list for data logging are based on the connected vehicle or selected vehicle profile. Its all the available channels,and you are selecting the few that you want to log.
    Are you saying it would be helpful to have the things available to log, match the names of the various axis and table values in your HPT file?
    Mar 2018
    447
    Yes.
