LM4
LS9 cam
Large Ebay intake manifold
102mm throttle body
3 bar map
42lb injectors.
4l60e
4.56 gears
33" tires
This is in a 99 Jeep Cherokee. I did the OS conversion to SD and made some trans changes to help with the shifting because it has a corvette solenoid and the 1 2 was violent. The issue im having is we are getting 6 to 8 mpg. Im datalogging and vcm scanner shows both o2's reading normalish and the long term and short term are pretty close. Im still not done tuning it but the fuel economy I dont understand. I should be getting more than 8 mpg. It doesnt smell like fuel and seems to be running rather well and makes good power. I attached my current map, dont beat me up to bad on the ve table as this is the first trip out after finding the throttle body set screw was adjusted so it never shut all the way. I had the last map tuned to within 5% and was still getting horrible fuel economy, but I started messing with it to see if I could get the fuel economy better. Either there is a major issue in my maps or maybe its a mechanical issue in the diffs or something. I am just trying to rule out a shitty tune. I dont usually tune gm stuff so I could have missed something. Let me know what you think. Thank you for any help you can give.
