Results 1 to 4 of 4
Thread: Log Data Wideband
    Apr 2023
    7
    Cool Log Data Wideband
    Hello, I recently purchased an Innovate wideband meter: https://www.innovatemotorsports.com/...-kit-3-ft.html I would like to know how to log data to VCM Scanner via USB serial cable Thank you
    Jan 2015
    Arizona
    439
    the bleow are just a few links i grabbed from a google search [how to hook up WB to USB serial cable hptuners]
    hope this helps some
    https://forum.hptuners.com/showthrea...l-port-adapter
    https://www.youtube.com/watch?v=mGcEw29XZBQ
    https://www.performancetrucks.net/fo...tuners-558840/
    https://ls1tech.com/forums/pcm-diagn...-scanning.html
    Apr 2023
    7
    Quote Originally Posted by bk2life View Post
    thanks friend, I asked because I can't find how to install that wideband, but I think they are all installed in the same way, thanks
    Tuner mjc79's Avatar
    Oct 2020
    Kansas
    78
    I use this exact wideband in my tahoe. The transform function data in the scanner for the lc1 and lc2 is the same as your mtxl so you can use either when setting the wideband up
    02 Tahoe, Rebuilt 5.3, PRC 2.5 heads, BTR Stg2 V2 cam, 50lb Injectors, Speed Engineering LT's, Offroad Y, Magnaflow catback, Built 4L60, NP241 swap etc etc...
