Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: SD Tuning - What to do after the table is complete - i.e. what do you turn back on
    The thing about these knock sensors, they can output a valid, but wrong, signal when they are getting to end of life. Old O2 sensors can do the same thing. There are more failure modes than just shorted or open.
    Good point. I think I will be safe and replace them both. I cannot remember if they were replaced when I rebuilt the engine.
    1999 6.0L LQ4 block
    243 heads
    Upgraded rods with LY6 pistons
    BTR LS3 stage 1. - 221/228 .608/.571 112+2
    2010 Camaro SS Exhaust Manifolds
    2006 LS2 Injectors
    Stock truck intake - DBC
    2,742
    Quote Originally Posted by Keep View Post
    Nope, no codes, nothing else to indicate an issue with a knock sensor. I remember seeing/reading something about needing to "desensitize" the sensors with any changes. I will dig into that a bit.
    When knock sensors go bad they either get way overly sensitive, loose all sensitivity, or happen to throw a code. I'd try new knock sensors especially if they have some age
    Tuner at PCMofnc.com
