I haven't seen anything about this but on a 2015 Tahoe I am tuning there is a Clutch air purge master enable/disable. Should that be disabled when raising line pressures? I know on the 2019+ Rams with 68rfe there is a clutch air purge or something similar that has to be disabled when raising line pressure or you will burn up the clutch packs. Any help is greatly appreciated!
Dylan
