Hello All,
I'm very new to tuning and was able to configure the basics to get the engine to start/run successfully. Now I'm feeling a little overwhelmed as to what to do next. The truck starts and runs smooth.
Looking for some direction advice. Config/scanner files attached.
Mostly stock 2001 DBC engine swap into a 65 C10 with 4l60E
BTR Truck Norris CAM (NOT NSR)
BTR Beehive Springs to match cam
Holley Sniper 3 bolt throttle body (85mm)
Patriot LS cast exhaust manifolds.
EGR delete plugs
Converted the fuel rail to returnless. (Removed regulator on rail and replaced with fuel gauge and plugged return line - (using corvette regulator/filter)
Otherwise all stock....
THANK YOU IN ADVANCE
