When i enable pedal follower it throws a wrench light any ideas on what else should be changed to fix this?
hello friend this is common in ford, if you have problems with transmission knocking when you turn on the wrench, it could be due to a malfunction of the MAf sensor OR MAYBE Your IMRC are simply not opening so when accelerating it fails and it could even turn off, check first the maf sensor put your datalog in the vcm scanner, activate the maf if it does not register data your problem is there it could be a fuse or the harness if it is working, check that your imrc are opening
car does not have imcr from the factory
