Results 1 to 1 of 1
Thread: L59 injector data - From E85 WITH return TO 2000 LM7 gas with Return
    Sep 2022
    17
    Looking for input to modify additional params other than Flow rate, as well as the flow rate itself (stock=26 lb/hr). I am not 100% assembled, so cant monitor fuel pressure yet on this vacuum regulated LM7. Currently my idea is to start at the 36 lb/r for all flow values, and change nothing else(for injector data) based on I should have 58psi with the otherwise stock fuel system. Is this sound thinking? ideas or experiences please and thank you!
    11.8cr, 231deg Int.
