I am trying to get the DFCO to work on my Jeep
swap with a 5.3 manual trans and with no VSS input to the GM P01 PCM. I set the Speed vs Baro to 0mph and the fuel will cut off while on throttle at around 1600ish RPM. So its like it set my rev limiter to that. Is there another setting I need to change to get it to work without a VSS? Only other thing I can think of is setting the TPS values to much lower across the chart? It would be nice to get this work for fuel savings, able coast down hills without riding the brakes and for it to stop hanging on the revs in between shifting.
