Hey guys, your opinions regarding meth vs meth/ water injection in twin turbo 07C6Z06. I have run straight meth for the last 10 years vs. race fuel for octane and safety in my forged LS7. It allows me to run good timing up top @ 16* with no Kr on 93 octane pump gas. I usually need to replace the meth pump every 3-5 years due to the corrosive nature of the meth. With meth spraying from 3200rpm@ 8 lbs of boost up to redline@ 16 lbs boost my AFR?s go from 11.5 to 10.5. I don?t want to pull fuel from the tune in case the meth fails, but the car definitely runs rich from about 4K rpm up. In a perfect world I would like to keep it in the 11’s.
I started experimenting with a 50/50 mixture of meth and water. It brought my AFR?s up to 12 - 13?s which is higher than I wanted to go. My question is, I still have zero Kr even at top boost with 16* timing because the water/meth still is doing what it should and disrupting the flame front in the cylinder burn process. I just lost octane vs. 100% meth. Do you think these AFR’s are OK as long as I have no Kr? The car still runs great this way and decreasing the richness is apparent in the exhaust residue, plugs, etc. Thoughts?
P.S. - I have the Lo Octane spark table set lower just in case I do get Kr
