Short Term Fuel Trim
I have an LS3 swapped Monte Carlo that I'm running through lingenfelter with gen 3 pcm. I have my wideband on my other vehicle at a friends house that i will pick up sometime this week. Engine start and idles fine but when i go to drive the power isn't there and if try to give a lot of gas out the hole it bogs. Can someone look at the short term fuel in the log and tell me what they see since i can't see the actual afr without my wideband.
23-03-11 13-48-35_F.hpl
the computer trys pulling 37% fuel from it when it goes into closed loop at idle....
what have you done to the ECM ? or is it running stock LS3 info?
