I have an 02 Silverado single cab 4x4 with a 4l80e 3.73 gears and circle D torque converter 3800-4000k stall with a 427 ls7 stock bottom end with Frankenstein m311 11degree heads Rec port cam motion cam 244/256-112+4 has 80lb injectors flex has a gm flex sensor on feed of fuel rail Holley high ram 92 mm throttle body
p01 computer, ls1 to ls7 swapped. just looking for help on a startup tune to get it running and onto the trailer for professional tuner. thanks in advance
timing log ls7.hpl5.3 with ls7 tables.hpt
