i have a 2001 silverado 5.3l 4x4 with intake and currently did an EGR delete need help with tune i already shut off codes but need help adjusting tune i keep getting code for bank 1 & 2 lean. If i need to upload the file i can. Thanks in advance
Definitely post the tune and some data logs with the usual channels to see what's going on.
2000 Camaro SS M6, LS3 NA 427~581whp/549wtq
2002 Trans Am WS6 M6, stock
1966 Mustang coupe, 289/A3
Lean codes means your LTFTs are more than +20%. Shouldn’t have that with just those mods. Be more specific about intake. Like intake manifold or cold air intake. Look for vacuum leak possibly where EGR tub was removed or an air leak after the MAF.
volant cold air intake. let me hook back up and ill load the file and logs.
hi guys sorry it took mew a couple day to upload the log file and tune file been super busy at my shop but here are both thanks in advance for any help. Also you can see that the LTFT is above 20 2XLS1 statedherb clah 2000 BRWN TRUCK 5.3 MARCH 7 2023.hpt2000 silverado 5.3l log file 2.Channels.xml
