Greetings to all and thanks in advance for any guidance. I'm struggling to accept that my tune is anywhere near acceptable after having it back a couple of times to my tuner for work. So frustrated with the way its running, I went out and bought everything I needed to scan and tune myself because I know this is not right. Not being picky, just don't want a car that will hardly idle at all until fully warm, hunting like crazy, requires throttle inputs to keep it running until warm, etc. When warmed up, it stalls coming to stops or the idle hangs at 1,400, then drops and struggles. Needless to say, totally miserable to deal with. Outside of that, actual performance is really good, except driving isn't only that, it involves stopping for lights, etc. Miserable.
The car is a 2002 C5, owned and well maintained since new. 40k miles. Prior to the recent heads/cam/intake build, the car ran great with AR 1 3/4 long tubes, mail order tune from ECS, McCleod RXT clutch, Stoptech ST60/40 brakes all around, etc.
Heads , cam, intake included virtually every top shelf part I could think of to make more power, more reliability. I spared no expense.
CamMotion Titan 4 cam 227/232 113+4 (not a difficult cam to tune and reputation for good street manners)
TrickFlow 215 heads, fully worked over by TEA, milled to 61cc.
FAST 102 Intake, Vengeance Racing ported, with Nick Williams throttle body.
Harland Sharps roller rockers.
BTR dual valve springs
Johnson 2110R lifters
Manton pushrods.
Vengeance Racing 36lb injectors
Melling oil pump
C5R timing chain
ATI Balancer
Calloway Honker
and every supporting part, gasket, etc.
I wanted max effort build that still had good street manners and good road course racing performance. Car makes great power, a bit under 500 RWHP.
I'll attach a scan of the cold start and the current tune and go from there. I'm betting much of the trouble starts there, where a competent tuner would be able to get this right and explains why the return to idle and idle qualities when warm are total garbage. Hoping to gain some insight and either get it to a better tuner, or begin to learn how to work these problems out myself. Thanks for your thought.
