~Greg Huggins~
Set your dtc's back to report and then use these channels. Looks like it's in open loop fault...
~Greg Huggins~
Does this Diag list look any better?
2009 CTSV Sedan CRT
TMS 427, Modified Huron Twin Kit, BW-S369s, Greg Good CNC Brodix BR7s, Lil Jon Turbo Cam, PTC converter spec'd by Dusty Bradford, ID1700s, FORE Fuel System, built 6l90
1990 Mustang tuned using Holley EFI
Go get a stock file from the repository, open it as Compare, then change your DTC settings until the green outlined box goes away, that means both files are the same there.
Need attention:
P0030
P0050
P0053
P0059
P0133
P0135
P0153
P0155
P0171
P0172
P0174
P0175
P0601
P0602
P0603
P0604
P0606
P060D
P1133
P1153
P1174
P1175
P2138
Some are Second Error, when they should be First Error.
Post #8 is a stock 2009 CTS-V File
2013 OBM A6 CTS-V Coupe
Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
2006 Black Raven STS-V (Traded In)
Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
Also make sure to log starting before cranking. These things will do an 02 test on startup, starting with bank 1. Do you happen to know if it was ever tuned with SCT before? You also stated this started after O2 replacement - were the right ones used?
~Greg Huggins~
I doubt the car was ever tuned using SCT. This started when I had my car tuned because I put the wrong sensors back in. I didn't know which ones were upstream/downstream by looking at them, and I grabbed the wrong ones. My downpipes only has provisions for 1 o2 in each pipe.
But like I said, the car runs extremely good. I was just wanting the closed loop function working like it is supposed to. I thought it would have been an easier task than it has been to make it work.
2009 CTSV Sedan CRT
You might want to save yourself a headache and grab some more new upstream ones and stick those in just in case one's still the wrong part number. If it's in open loop the driver's side will be the wrong one as it's the first that gets tested and causes a full engine default. Still might want to check the passengers too.
I only ask about sct because I've seen them change things in the background restoring to stock which caused bank 2 defaults even though nothing was wrong with the O2's themselves.
~Greg Huggins~
2009 CTSV Sedan CRT
That's something different. With a regulator referenced 1:1 to manifold pressure, the delta across the injector is always the same - vacuum below atmosphere lowers rail pressure from the base, boost above atmosphere raises rail pressure above base. This applies not only to the Injector Flow Rate table (which is flat, as is correct for a referenced regulator), but also the Offset vs Press vs IGNV table (which has not been changed to suit the new regulator).
