I do not care where you worked. I am not wrong in this respect. I am very well versed in camshafts. Change the LSA by moving the valve timing events and you change the overlap. Change the overlap and you change both idle vacuum as well as the VE of the engine. Both of which require VE table changes. As I previously mentioned even changes in intake and exhaust system also change the VE tables. I have run the same exact Comp grinds with 4* tighter LSA. Idle vacuum was down, low speed VE was down, and it moved more air overall though the same MAF sensor with the same MAF calibration once it had a little RPM in it. I have also had to retune for higher ratio rocker arms because the VE table is altered enough to warrant changes. Overlap also happens to be my first consideration when picking a cam rather than merely a number that exist off other specs.
