Whats up yall, just the other day I finished my LQ9 swap that ive been working on for about 18 or so months. Rebuilt from the ground up with new bearings, rings, oil pump, etc and a bunch of other non-performance stuff (gaskets, bolts, etc.). I installed 821 heads with LS3 intake manifold and Deatschwerks 65lb LS3 injectors. My car was tuned before hand and ran great until it burnt a couple valves. After I uploaded the new tune, I was expecting to be running leaner than normal since it was tuned for a 5.7 and now its a 6.0 without changing the fuel. After the first fire, I noticed my wideband was reading everything from 2:1 (!!!!) to 22:1. I was not aware these sensors could even read that low. After doing some research I found that the lowest they can read is 8:1 since I have the 4.9 sensor. First fire it stumbled and acted like it wanted to die with AFRs staying around 7:1-8:1 and overall didnt want to idle very well. After lowering the min pulse width to .350 ms and changed the min fuel miligrams to .010 and uploaded the tune. It fired over quickly and sounded much better with the rpms fluctuating +/-50 rpm from target but my wideband was still reading 7:-8:1. After a few more seconds it started to go all over the place, all the way down to 2:1 and all the way up to 22+:1. Am I missing something? Could the sensor itself be bad just from sitting out gently tucked in the trans tunnel for 18 months?? I live in Florida so its typically quite humid for most of the year, though my car spent the entire time in a closed garage. I spoke with Deatschwerks and they confirmed my tune has the correct injector information. What do you guys think could be the issue?? Ive included my tune below as well as a short log of starting the car up and idling. I didnt want to do it for too long incase I am actually running that rich. I apologize for being kind of all over the place and I appreciate any help in advance!
