Results 1 to 6 of 6
Thread: Linear and offset calculations for MAP
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    I have a new 3 bar MAP that came with a voltage/kpa table vs. linear and offset values. I was using the LS9 MAP so my values in HP Tuners are set for 312.50 and -11.25. Is there a way to calculate the linear and offset values for this new sensor from the attached table or do I need more info?
    Thanks for your help!
    Nov 2017
    1,464
    y= 62.74x + 1.32
    You can look up a y=Mx+b calculator on line. M is the slope, b is the offset, x is voltage and y is pressure.
    7,646
    It's 0.016 volts per kPa. To figure what kPa would equal 0.00v (this is what the Offset is looking for), divide 0.25 by 0.016 then subtract that from 17.
    It will be a positive number, not negative like the LS9.
    Sep 2008
    Charlotte, NC.
    242
    Thanks...got the offset, so now to get the linear value, if I plug that into the y= 62.74x + 1.32 or y=mx+b formula, what do I use for the "x" value in voltage to get the HP Tuners linear number?
    7,646
    Read the tooltips. Linear is what it would be at 5.00 volts, and that is shown in the little chart. No math needed.
    Sep 2008
    Charlotte, NC.
    242
    Appreciate it.
