Results 1 to 10 of 10
Thread: Speedometer Showing Too Fast - 4L80 Not Shifting Correctly
    Nov 2020
    24
    Did a 4L80 swap in a 72' Suburban behind a 5.7L engine. Had to do a segment swap for the 4L80. Now the transmission shifts, but it shifts too fast. I have updated the speedometer calibration using the gear/tire wizard, but speedometer is still showing way too fast. I have attached the current tune, and the log. Can someone please take a look and tell me what I am missing? 23-02-09 16-26-09.hpl2001 P01 5.7 Segment Swap 4L80E.hpt
    13,565
    I wonder if it has anything to do with you starting off with the corvette operating system. Those use a transaxle and not a standard transmission.
    Nov 2020
    24
    I didn’t think about that. Anything I can do to fix that? Using this same PCM?
    7,649
    The setting for Pulses Per Rev (the number of teeth on the thing being read by the sensor) does not always follow the tooltips in the editor - it says it'll accept a range of 0 to 256, but the actual range each OS is able to use is often much narrower range.
    Feb 2017
    miami
    1,799
    If its showing speed when you rev in neutral the two vss plugs are swapped
    Nov 2020
    24
    Is there anything I can try to get it closer to reality?
    Nov 2020
    24
    No it is not. Just tried that.
    Tuning Addict
    Jan 2015
    6,816
    If it's shifting too fast then it's probably not getting the correct speed inputs - most likely missing the TSS
    Add TSS (turbine shaft speed input) and VSS (Vehicel speed input) all to your log. TSS should be present and match rpm with the engine running then vss should be changing with the vehicle rolling. If you're missing one of these then you're missing one of your inputs (either wired to the wrong pins/wrong connector at the ecm) or hooked to the wrong sensors. You should be plugged into the front TSS speed sensor and tailshaft (VSS speed sensor) plugs. The center (tss output) speed sensor should be bare or not have a wire going to it. You should have also had to either install a plug and play harness or ran two new wires to your ECM for the tss input.
    ~Greg Huggins~
    Dec 2019
    MS
    567
    2wd or 4wd?
    Nov 2020
    24
    Quote Originally Posted by RDF1 View Post
    2wd or 4wd?
    4wd
