I encountered an issue with the MPVI2 that i purchased. I'll give a little background of the ecu / setup for context.
The setup is a 2001 LS1 / T56 with a PO1 ecu that was previously flashed by wiring specialties (just basic VATS delete / CEL / SMOG). Car currently runs and drives. Wiring harness is a thinned-out F-body harness. Battery is fully charged and, on a charger, when I am attempting to flash. Laptop battery is charged. Cable has been swapped several times. VCM scanner is confirmed not running in the background. I am attempting to flash with a two universal credits.
I can pull the map with VCM suite, make changes, but when i go to flash the percentage never goes past zero, and will eventually error with a "write transfer time out". I have attempted to write entire and write calibration. I have also attempted to flash a stock map from the repository. I have submitted a trouble ticket with HPtuners, but I figured I would post on here in case anyone has any ideas.
