Results 1 to 17 of 17
Thread: Lean,lean,lean
    Jun 2020
    34
    Lean,lean,lean
    Got a startup tune and im lean lean lean....can any one help
    6.2, 95lb, s475, btr stage 3, 4l80, 410 gearsDAIRL 75 VERT AS IS.hptdb1.hpl
    AFR IN THE HIGH 19s ON E85......
    Jun 2016
    Tuscaloosa, Alabama
    71
    Is that 95lb injectors?
    Jun 2020
    34
    Yes
    Jun 2020
    34
    Afr says 19.....on e85
    Jun 2016
    Tuscaloosa, Alabama
    71
    Need to start with OS change to 2 bar OS, then the correct fuel injector data. Have you changed the map to a 2 bar map? What style fuel system are you running? Fuel pump?
    Jun 2016
    Tuscaloosa, Alabama
    71
    also alot has to change to run e85 for stoich. also its a GEN 4 ecm
    13,576
    His tune is scaled for the large injectors from the looks of it. No idea if it's scaled right because he didn't say who's injector they are and if they came with data.
    Also he's not running a alcohol sensor, which doesn't help him at all.
    Jun 2016
    Tuscaloosa, Alabama
    71
    Once I realized it was a Gen 4 I realized it was scaled.
    Is wideband being logged on the scanner? Didnt see it on this one.
    Jun 2020
    34
    Not yet but its screaming at me.....anyway to get more fuel acrossd the board
    Jun 2016
    Tuscaloosa, Alabama
    71
    what size pump and type boost referenced regulator you using?
    13,576
    You have to provide us with more information about the injector data and tell us why you are running E85 without a alcohol sensor.
    Can't just smack it fuel and hope it works. If other parts of the tune are wrong you will just make it worse.
    Jun 2020
    34
    Understood. Fic injecters, walboro 450, i dont have to use e85, can drain it in the am, fuel regulator connected to intake vacuum for boost reference. Im not smacking it as if the tune is on hit. i know its off so this is just idle and take it slow. Has not seen 3k rpm as of yet, so no boost. When i get on the gas a little the afr drops to 15, 16 range. i will have to locate wiring to connect wideband to hpt. its all tucked away for some reason....lololol
    Jun 2020
    34
    i am using 3 bar sensors
    Jun 2020
    34
    data sheet
    Here is what I have
    L92 6.2
    built 4l80
    Btr stage 3 turbo cam
    95 lb fuel injector connection
    s475
    4.10 gear
    magna fuel 4303 750
    circle d @3600
    275/35/26
    aeromotive 13101 efi reg. A1000 injected bypass
    -8an feed -6an return
    6.2 truck intake
    ls9 maf
    ls9 map sensor
    fuel pressure 58 psi @ idle
    90lb run log 93
    db1 on e85
    What maf sensor are you using? IAT sensor calibration and IAT2 is different in the tunes you attached. What is the fuel pressure at idle? 58 psi?
    Jun 2020
    34
    Quote Originally Posted by Mr.z0611 View Post
    6.2 truck intake
    ls9 maf **********
    ls9 map sensor
    90lb run log 93
    db1 on e85
    565
    DAIRL 75 VERT AS IS E85 Try.hpt
    Try that on e85 and see what happens
