Results 1 to 6 of 6
Thread: Stinky idle and poor fuel milage
    Jul 2021
    5
    i am not a tuner for the most part just a normal mechanic.
    i have been using hp tuners to change tire size gear ratios trans tuning code and vats deleat on swaped vehicles.
    i have a 2009 silverado 1500 4.8l has tsp stage 3 low lift cam and long tube headers installed.
    i had the truck tuned by a dyno shop that came highly recommended.
    the truck runs real good given its only a 4.8 on 35 inch tires but it smells real rich at idle like makes eyes water rich.
    i was have been watching data and fuel trims are real high at idle and part throttle im not sure if this is normal after tuning i have checked for vacuum leaks and cleaned the maf. also i cant seem to get vcm scanner to do the idle learn
    i bought an afr setup to get more info and make a log file for anyone who is willing to look at it.
    any help would be appriciated.
    the log file posted is without the long term fuel trims turned on that is how i got it back from the dyno shop i have since figured out how to turn them on but need to record a log file to post.
    Mar 2011
    Ripley, MS
    1,865
    It does have some high fuel trims. The first thing to do is a leak check on the exhaust system. Any leaks before the oxygen sensors could cause an issue like yours.
    Jul 2021
    5
    Did that smoke tested exhaust no leaks.
    Tuning Addict
    Jan 2015
    6,814
    Injection timing, O2 settings for the headers and idle spark - fix those 3 and you'll be good to go. You'll also need to retune your air models, but that should be given. You'll never get rid of all of it, but should be a lot better. In fact this tune looks a whole lot like another one on here that had to be fixed a month or so ago. You also have some heater codes for the O2's you need to get fixed or just delete in the cal as they are post O2 codes.
    ~Greg Huggins~
    Jul 2021
    5
    I got rid of all of the rear o2 codes it was setting no codes come up.
    Thanks for the information I will start researching those 3 things and see if I can get them dialed in.
    I?m sure I will have more questions later
    Jul 2021
    5
    these are the log files with the long tearm trims on
